Discussion topic: iPhones not connecting to wifi
Message posted on 08 Nov 2024 04:57 PM
Our house hold iPhones are not connecting to our home WiFi.
we have tried turning everything off, re connecting etc but they still won't connect.
router is showing all lights ok and sky tv working fine
Message posted on 08 Nov 2024 05:05 PM
Re: iPhones not connecting to wifi
Give this a try:
Go Settings > General > Transfer or Reset [Device] > Reset > Reset Network Settings. If you're using iOS or iPadOS 14 or earlier, tap Settings > General > Reset > Reset Network Settings. Then go to Settings - Phone - My Number and change it if it is wrong, then reboot the phone. You will need to set up your Wifi connection again.
