Discussion topic: iPhone not connecting to Sky wifi
This message was authored by: Esther26
We switched two days ago from BT to sky broadband. The tv has connected to the wifi but when we try connecting our iPhones, we gwt a message to say we have inpuuted the incorrect password, even though the password is taken feom the information on the back of the router.
Re: iPhone not connecting to Sky wifi
@Esther26
If you are seeing an error about entering the wrong Wifi password then make sure you are not getting a 1 and l or a 0 and O muddled as it is quite easy to do this. It must also be entered as show on the hub itself so use upper case letting if required.
