Discussion topic: iPhone connecting to fibre
Message posted on 12 Jul 2025 01:58 PM
iPhone 15 connected to fibre broadband displays this message:
sky***** isn't compatible with iCloud private relay.
to access the internet on the network, you need to turn off private relay.
turning off private relay means this network can monitor your internet activity and your ip address will not be hidden from known trackers or websites.
Has anyone come across this before and know of a solution please.
many thanks
James
Message posted on 12 Jul 2025 02:39 PM - last edited: 12 Jul 2025 02:45 PM
Re: iPhone connecting to fibre
@James0073 Yes and you need to either do it, or go to apple site and deal with it there!
Just search the Forum for private relay will be quicker for you!
