Discussion topic: iPads won’t connect to wifi
This message was authored by Beck666 This message was authored by: Beck666
Since last night neither of our iPads will connect to the Wi-Fi.
tvs & phones are fine but not ipads
any ideas anyone?
Re: iPads won’t connect to wifi
@Beck666 there is an update to iPados which may have caused the issue. Tell the tablets to forget the Sky connection tgen powercdown them by holding the sidecand one of the volume buttons unitl the power slide appears.After rebooting the units re-add the Sky connection.
Beck666
Thank you. I’ve tried that and it’s still not working. When my iPad is turned on it connects then immediately disconnects. My daughters iPad won't connect at all
