Discussion topic: i can only pick up wi-fi in the room where my sky max hub is.
Message posted on 17 May 2025 10:10 AM
i switched to fibre broadband. when connected i didnt have a great signal in the lounge. after soeaking to sky i was adviced to have a sky max hub. this seem to be worse i now only have a good signal in the room with the hub in. other rooms are poor . and i cant get to speak to any one on the phone
Message posted on 17 May 2025 10:25 AM
Re: i can only pick up wi-fi in the room where my sky max hub is.
@sue1221 When advised to get the Sky Max, did you also take the subscription addon at the same time?
Message posted on 17 May 2025 10:27 AM
This link explains about the add on:
If you get this added then Sky will supply you have up to 3 pods.
