Discussion topic: how to call sky ireland from a UK mobile
This message was authored by: qwer123
this was a discussion thread in 2024 but i'm wondering if this has been resolved since then. I need to change my contract so need to speak to someone (can't use the chat) but there is no number that works from a UK mobile phone number. A disgrace for a global company!
Re: how to call sky ireland from a UK mobile
@qwer123
These are the current methods for contacting Sky. (Depending on your reason for making contact some methods will be more appropriate than others) …
🟩 📞 Customer Services by dialling 150 (free) from either a Sky mobile or a Sky Talk landline. The forum doesn’t allow the display of other numbers.
All calls will start automated which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
🟩 online help via this link
https://www.sky.com/help
🟩 Sky Assistant 💬 should also be available via
🟩 Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
Note ~ ROI customers 🔹If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required. There should be an 0818 number. The Sky Ireland phone lines are closed at a weekend.
