Discussion topic: how do i check if other device are connected to my wifi
This message was authored by: Princessm44
Message posted on 18 Jun 2025 05:32 PM
how do i check if other device are connected to my wifi. I know other pople use it but im trying to find out who
Message posted on 18 Jun 2025 05:40 PM - last edited: 18 Jun 2025 05:41 PM
Re: how do i check if other device are connected to my wifi
@Princessm44 What hub do you use! Web connect to the hub http: //192.168.0.1 just strip out the space between : and the /, will take you to the status page where YOU may see some / all off the connected devices. Then you have to work out who is who.
