Discussion topic: fortinet routers/switches/vpns
Message posted on 30 Dec 2023 08:30 PM
Re: fortinet routers/switches/vpns
XCY Router Intel i225V 6 NIC 2.5G Gigabit Ethernet Enterprise Firewall Appliance pfSense OPNsense Gateway Linux Ubuntu Mini PC
This any good?
Message posted on 30 Dec 2023 08:34 PM
This is the one I used and upgraded the memory to 16GB.
VENOEN Firewall Micro Appliance 2.5gbe Firewall mini PC Celeron J4125, 4x2.5GbE I225-V LAN Firewall Router PC, 8GB RAM 256GB SSD Fanless PC, AES-NI, HD-MI, VGA, 2xUSB 3.0, SIM Slot, VPN Server.
Message posted on 30 Dec 2023 08:37 PM
The mini PC you have picked is also good for an OPNsense firewall. 😀
Message posted on 30 Dec 2023 09:04 PM
You've made me so happy because sky option 61 has been the bane of my life and for years I've been trying to find a solution and now I have, thank you so much!. I will definitely continue to speak to you if that's 👍
Message posted on 30 Dec 2023 09:07 PM
If any help you need with OPNsense or Zenarmor don't hesitate to enquire... 😀
Message posted on 30 Dec 2023 09:13 PM
Will do!!
you've been so helpful 🙏
I'll draw up an illustration tomorrow of the homelab I've dreamed off ☺️
Message posted on 30 Dec 2023 09:24 PM
For a media cluster don't forget to look at Ubuntu. DRBD and OCFS2 file system which requires a disk for Ubuntu and 2nd SSD disk for shared media on the cluster mini PCs.
Message posted on 30 Dec 2023 10:52 PM
Been looking at 64 gig, 8 core, 16 thread, ddr5, firewall mini pc routers/servers/gaming/etc
they come at around £700+
Looks nice, but I looked at the gen and they are old ones? 11 gen some are 10!
Cant find a 12 or 13th gen with these specs anywhere
How have you setup your router to bypass or authenticate skys 61 option?
Is there an option you can choose in the firmware? Will I see different advanced options once I'm all setup with the router and is it easy to setup?
Message posted on 30 Dec 2023 10:59 PM
By all accords, the interface on OPNsense is a nicely designed web interface, pretty simple to set up NGFW in comparison to others but you do need to go down to the SSH to perform complex tasks on infrequent occasions. As an example, I went down to the shell level to adjust the resolver and forwarders for DNS.
Message posted on 30 Dec 2023 11:02 PM
I found a better server homelab virtualisation (T9 Plus Mini PC Intel Alder Lake N100 16GB DDR5 1TB NVMe SSD)
Most likely order 3 of these and these will be my go to for homelab use
The router you have will be the firewall or should I get something high spec?
Message posted on 30 Dec 2023 11:05 PM
OMG...not a DNS! NIGHTMARE!!
I lost my cool so many times cos of this 😄
Message posted on 30 Dec 2023 11:08 PM
My resolver and DNS forwarders do this for our network, randomly selecting DNS forwarders...
Message posted on 30 Dec 2023 11:14 PM
😄 seeing this gives me hope
Ya, definitely will ask for your help when I receive all the goods and set it all up with open sense
Goodnight for now, thank you for all your help 🙏
Message posted on 31 Dec 2023 10:13 PM
Message posted on 31 Dec 2023 10:22 PM
Evening mae!
I posted a quick diagram of what im trying to accomplish
The rack is a must, 10 or 12 inch rack but some of the hardware I still may purchase come at 19 inches...so i may have to go for an ugly big rack...
Essencially i'd like to have a rack on display, yep, i'd like to look at it each time i pass the room 😉
May even purchase a cheap old thinkpad to have under the rack on a slider so i can manage it right there instead of having to go all the way to the main computer.
I'll have ubuntu on the thinkpad or maybe some dual hybrid with windows or just boot into windows or linux with a flash drive.
But the 3 mini pc's i showed you before will be the server's for virtualization and using Qubes http://www.qubes-os.org/intro/ and tails I believe comes with qubes, not sure, but can always add this later, https://tails.net/index.en.html
