Discussion topic: connent TV to router via wifi
This message was authored by Albatross10 This message was authored by: Albatross10
I need help to connent TV to router wifi after a reset of the router - now I cannot get my wifi to work to connect my TV - how do I do this?
Re: connent TV to router via wifi
@Albatross10
Well what have you tried so far? What errors are you getting/where are you getting stuck? What TV brand is it?
I am NOT a Sky Employee
@Albatross10
If your television has the option to do a WPS connection (where you click a button on the TV remote and then press a button on the internet router) I'd suggest trying that.
On a Sky Q Hub the WPS button is on the front, while on a Sky Broadband Hub it's low on the right hand side.  Both have the WPS arrows.
Albatross10
Problem solved bydisconnecting the TV & Router then first reconnecting the Router followed by the TV. The next step was to reset the Hub connection along with the Password - then it worked. Thanks to everyone who helped.
Neil
