Discussion topic: connect landline to hub max
This message was authored by: Keltis
I AM NEW TO SKY BROADBAND, CONNECTED YESTERDAY. I HAVE WIRESLESS PHONES WHICH DO NOT REQUIRE CABLE TO LANDLINE OTHER THAN MASTER ONE.
MY PREVIOUS SUPPLIER NOW ONLY REQUIRED ME TO CONNECT HUB TO LANDLINE TO CONNECT TO BROADBAND AND PHONE, ONE CABLE.
ON MY NEW SKY MAX HUB I CANNOT CONNECT TO PHONE AS THERE IS ONLY 1 PORT ON MY PHONE BOX. I HAVE CONNECTED PURPLE TO HUB AND WHITE TO LANDLINE, ALL WORKS EXCEPT PHJONE.
CAN I PUT IN MICRO FILTER WITH TWO OUTLETS, USING SKY PURPLE TO HUB  SOCKET   AND PURPLE PORT ON  MICRO FILTER, THEN USE  ANOTHER SKY CABLE WITH PURPLE PLUG TO  HUB AND WHITE END TO LANDLINE?
THANK YOU
Re: connect landline to hub max
@Keltis  Is there a UK phone port on the hub?  Are you plugging your phone into this rather than the phone socket?
