Discussion topic: connect bt router to sky booster box
This message was authored by: Vonny61
I have tried several times to connect bt router to sky booster box.  Is this not possible? Thanks
Re: connect bt router to sky booster box
@Vonny61 you normally cannot mix kit from different ISPs there are exceptions but I doubt your combination can work. The SE210 is designed only to work between the Sky Q boxes or with the black Sky hubs.
Avatar for Vonny61
Just one ISP which is BT. Sky provided booster as TV kept losing its internet connection.  Just had a new BT router and the Sky booster doesn't want to connect to it.
