Discussion topic: can’t wait to leave sky
Message posted on 08 Mar 2025 02:37 AM
had enough of this ridiculous wifi going down everyday , one month left and we're gone
Message posted on 08 Mar 2025 04:54 AM
Re: can’t wait to leave sky
@ryan120
