Discussion topic: accessing gmail on sky broadband
Message posted on 18 Aug 2025 03:27 PM
i have transferred from BT to Sky and now cannot access my gmail emails on laptop (I can still get them on iphone) except by going through webmail. What can I do to get gmail on Outlook as before?
Message posted on 18 Aug 2025 04:21 PM
Re: accessing gmail on sky broadband
Chsnging your broadband supplier should prevent you from being able to access your emails so what is happening when you try to, if you see an error message what does it say ?
Message posted on 18 Aug 2025 04:29 PM
Itt is not allowing me to access gmail on Outlook. on computer. I am still able to access it on my iphone. Should my computer be able to connect to the new broadband automatically?
Message posted on 18 Aug 2025 04:34 PM
@Confused28 sounds like Outlook has lost access to the Google account. Go into the settings as it is likely to be simply fixed by signing in again. Highly unlikely thst it has anything to do with your new Sky service.
Message posted on 18 Aug 2025 04:39 PM
But what is happening, is there a error message and if so what does it say ?
Message posted on 18 Aug 2025 05:36 PM
@Confused28 wrote:Should my computer be able to connect to the new broadband automatically?
Depends on what you mean. You will need to connect to the new SSID with the new password.
Can you access the web on the computer?
