Discussion topic: Xbox can't connect to wifi
This message was authored by RimmerJ This message was authored by: RimmerJ
Hi,
We had a new wifi boxed delivered yesterday! we are trying to connect it to the xbox and it won't work it is asking for SSID number?
Re: Xbox can't connect to wifi
@RimmerJ
Connecting your Xbox should be the same process as any other device, search for networks, select your Sky router in the list & then enter the password. There should be no requirement to enter the SSID manually. Can you send a photo of what you see?
I am NOT a Sky Employee
