This discussion topic has been answered Discussion topic: X (formely Twitter) not loading pictures and Videos on SKY BB
Message posted on 14 Jan 2024 11:29 AM
Yesterday morning I noticed videos and pictures on X would not load or play on either my phone or laptop when connected to wifi. Switched to 5G/4G on my phone and they then play fine. Switched off sky broadband shield and hasn't made any difference. Is anyone else seeing this? Thanks
Message posted on 14 Jan 2024 01:59 PM
It wasn't working on my laptop either. Just checked again now and it's working on sky BB now.
Message posted on 14 Jan 2024 12:58 PM
Re: X (formely Twitter) not loading pictures and Videos on SKY BB
@friedonion Are pictures and videos loading everywhere else when you are using your Wi-Fi connection?
Message posted on 14 Jan 2024 01:00 PM
Yes fine on all other sites. Just issue with X that's all. This has happened before and it was the sky broadband shield blocking it but not this time. Have reported it to Sky anyway
Message posted on 14 Jan 2024 01:02 PM
@friedonion Is this through their app? Have you tried it on a browser also?
Message posted on 14 Jan 2024 02:01 PM
Spoke too soon. Some new tweets just loaded and not playing videos or showing pictures again.
Message posted on 02 Aug 2024 07:53 PM
Having same problem. Works fine with phone network but not with WiFi
Message posted on 28 Sep 2024 09:30 PM
I have the same issue.
Tempted to just move provider shouldn't have to turn off WIFI when i'm sat a few feet away.
I'm guessing no one knows a fix?
Message posted on 14 Oct 2024 06:07 AM
I have just moved and installed sky max hub which is doing exactly the same. Loads tweets no pictures.
Turn wifi off and use 4g, twitter X works fine. Calling sky about setup today. Will post back if resolved.
N.B. can't get into hub settings either as hub won't set up properly. Though fibre was going to be wonderful.....not
Message posted on 14 Oct 2024 08:10 AM
@Trickydicky1000 even if you could get into the hub's settings there is nothing there that can sort this issue. Check the setting for Sky's Broadband Shield in the My Sky app as that can limit social networks if set too low by default new accounts are set to 13 IIRC. Otherwise its a routing issue between x and Sky which will get sorted..
If tge hubs settings dontvappear in the My Sky app after you havectried signing out, closing and re-opening the app then call Sky as they appear to have had an issue where a number of accounts were missed.
Message posted on 14 Oct 2024 08:29 AM
Will get sorted? Its been an issue for so long.
When we pay silly money for broadband it should work.
