Discussion topic: X box connection failing
This message was authored by: Stevek59
I'm new to Sky,I have broadband but my xbox one is not connecting to the WiFi all my other devices are working fine, I have tried all the suggestions for a fix ,but still no joy
This message was authored by: mae-3
Re: X box connection failing
@Stevek59
Try changing the MAC address assigned to the Xbox, it is under settings->General->Network settings->Advanced Settings and then select Alternative MAC address. The MAC address can be entered manually in the format required for a MAC address which is a hexadecimal number 12 characters long.
Avatar for Stevek59
  • Thanks , but I think I sorted it now , it was a problem with the ipv6 on the hub
This message was authored by: -rpnz-
Posted by a Sky employee
Hi @Stevek59 ,
The Xbox uses IPv6 extensively, and in general it should provide gamers with a better experience so I'd be interested to hear more about the issues you were experiencing, how you determined it was an issue related to IPv6 and what steps you took to resolve it, if possible, please?
@Stevek59
The packets are larger on IPv6 and for some games, IPv4 1500 MTU is better for latency so disabling IPv6 may be beneficial in some circumstances.
