Discussion topic: X box chess to wifi
Message posted on 21 Nov 2024 12:14 PM
X box chess to wifi
I have a new x box. When I try to get it to connect to my sky broadband it asks for a password but none I try work. I have used the sky broadband password and Microsoft password
Message posted on 21 Nov 2024 12:20 PM
Re: X box chess to wifi
Have you tried the password that is printed on your broadband hub as it should be that that is needs unless you have changed it. Make sure you enter it as it is printed so use upper cases letters if required.
Message posted on 22 Nov 2024 12:03 AM
Yes, I tried that. Thanks. It asks for the password for XboxSetup 5673. Whatever that is.
Message posted on 22 Nov 2024 07:31 AM
@Bovey1 sounds like there maybe an access pasword set on your xbox see https://support.xbox.com/en-GB/help/account-profile/signin-security/change-signin-preferences
The only password you need from the Sky hub is the WiFi password printed on the hub unless of coursexsomeone has changed it. However be careful it is quite easy to misread the label as Sky use the letters I and O and the numbers 1 and 0 which can catch people out.
