1
This discussion topic has been answered Discussion topic: Would the TP-Link Deco X55 AX3000 Mesh routers work with Gigafast ?
This message was authored by: Spots
Hello,We have a medium size house and my new sky SR213 router is terrible,(deadspots,timing out,limeted distance etc) All our previuous routers have worked ok !!! I am looking to buy a mesh system,before I do I just wanted to double check if anyone could help or advise if the TP-LINK Deco X55 AX3000 work ok with gigafast ?
Any help woulf be greatfully recived,
Thanks very much
Re: Would the TP-Link Deco X55 AX3000 Mesh routers work with Gigafast ?
@Spots the Deco range will not eaily connect directly to the line but you can either set the Deco up in Access point mode with yhe Smyhub;s wifitufned off which will give you beeter wifi. Alternatively you could connect it to the Sky hub in router mode which forms a double NATconfig which works for mostapps without issue.
