Discussion topic: Working from home signal drops.
This message was authored by: DP321
Can anyone please help? I work 1 week in office and 1 week at home. Whilst working from home my broadband keeps going off. Wnen I use sky app to test setting keeps saying all OK but I keep losing my connection.
Re: Working from home signal drops.
@DP321
When your broadband isn’t working use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
