Discussion topic: Work computer when I use teams or my headset, internet keeps dropping out and everything freezes
This message was authored by: julietdavid
Up until I changed my broadband to Fibre 500, all was working well.  I work from home, my office is a room above where my router is situated but now when on a teams call or phone call with headset via my computer, screen freezes and telephone drops out.  The IT company ran checks and said my internet keeps dropping.  Sky checks say all ok?
Re: Work computer when I use teams or my headset, internet keeps dropping out and everything freezes
@julietdavid
You can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
wfh: Remember Sky broadband being discussed here is a domestic service and whilst it's fine for those customers working from home to use it, they won’t receive additional or quicker support.
@julietdavid What did you change from and too, by chance when you upgraded did you also have a change of sky Hub at the same time!
