Discussion topic: Won’t let me change my Broadband shield settings
This message was authored by: And1960
When I go into Broadband shield it won't let me change the settings to specific times
Re: Won’t let me change my Broadband shield settings
@And1960  Broadband sheild is not for that. If you have broadband Max that does have the function to do what you are trying to do. Otherwise you can buy a third party router that has the ability to do this for you.
