Discussion topic: Wired works fine but WiFi says wrong password
Message posted on 13 Apr 2024 08:24 AM
Hi there
My sky q box and Xbox series x are hard wired to my broadband box and they work fine but when I try to connect to the WiFi it just keeps saying wrong password. Iv tried my current password and the ones on back of box. Iv tried reset 4 times and got no joy. Any help appreciated.
Toby
Message posted on 13 Apr 2024 08:48 AM
Re: Wired works fine but WiFi says wrong password
@Toby260581 Are you able to login to the router to check that you have the right password?
Message posted on 13 Apr 2024 08:55 AM
I can't log into the router as I don't have a pc that can be hardwired and the WiFi won't connect to my iPad or iPhone
Message posted on 09 Jun 2025 07:45 PM
I can't log in and how do I check the router
Message posted on 09 Jun 2025 07:52 PM - last edited: 09 Jun 2025 07:54 PM
@Stu62 See if this guide gets you to where you want to be.
New Sky Broadband Hub login password hack!
or
