Discussion topic: Will sky provide a new router?
This message was authored by: chrissiesms
My router is very old and often fails
Avatar for chrissiesms
Re: Will sky provide a new router?
Does sky provide customers with a new router? Mine is failing
@chrissiesms
If you call in a fault and telephone diagnosis suggests the issue is the router, then yes.  Otherwise you'd probably need to add a supplement such as WiFi Max to get an upgrade model.
Thank you very much!
