Discussion topic: Wifimax Hub poor to no coverage in various areas of the house
Message posted on 12 Dec 2025 10:00 PM
Just moved to Sky Gigafast 900 and looks good if yiu are near the router but coverage upstairs and in the basement are poor or zero coverage.
can I get boosters included invthe package?
Message posted on 12 Dec 2025 10:30 PM
Re: Wifimax Hub poor to no coverage in various areas of the house
Try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
A monthly charge applies, or it's available at no extra cost with the Full Fibre Gigafast+ packages so select "No, I still need help" at the bottom on the above link to get it added if you can't do it yourself via your account.
