Discussion topic: Wifi warning ⚠️ issues test your broadband connection
Message posted on 21 Jun 2024 12:57 PM
Just checking WiFi issues on broadband check your connection testing devices found an issue with WiFi loss of WiFi looked at the router everything seemed fine all the lights are on checked tv settings under broadband connection it was showing all connected nothing was found to be wrong checked ✔️ it all phone was connected to WiFi computer was connected to WiFi it was showing there for a long time until it went off back to normal
Message posted on 21 Jun 2024 02:47 PM
Re: Wifi warning ⚠️ issues test your broadband connection
@Jonathanphillip wrote:Just checking WiFi issues on broadband check your connection testing devices found an issue with WiFi loss of WiFi looked at the router everything seemed fine all the lights are on checked tv settings under broadband connection it was showing all connected nothing was found to be wrong checked ✔️ it all phone was connected to WiFi computer was connected to WiFi it was showing there for a long time until it went off back to normal
Sorry but if you're asking something there it's not obvious what it is?
