21 Mar 2024 03:10 PM
There is a massive delay on opening every webpage on all iphones that try to connect to the wifi. Constantly end up turning off the wifi and using mobile data instead. Wifi speed to tvs and laptop nowhere near as fast as they should be.
21 Mar 2024 04:00 PM
Posted by a Superuser, not a Sky employee. Find out morePlease post your router stats
21 Mar 2024 05:56 PM
I cannot get in to my router settings? Have tried username:admin and then password: sky and also my wifi password but neither work?
26 Mar 2024 10:41 AM
Posted by a Superuser, not a Sky employee. Find out moreAny messages you get?
Are you using an Apple device? If so use a non-apple device if poss or at least not Safari
28 Mar 2024 09:43 AM
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN WANoE 5468172 8351854 0 247210 44802 21:20:50 LAN Down 0 0 0 0 0 00:00:00 WLAN (2.4 GHz) Up 4419412 2603237 0 40220 218946 21:20:54 WLAN (5 GHz) Up 13515236 4103531 0 0 57058 21:20:52
28 Mar 2024 10:51 AM
Posted by a Superuser, not a Sky employee. Find out moreYour connection looks fine from the stats so I suspect your slowness will be down to WiFi congestion.
Have you tried the WiFi tips below?
