16 Apr 2023 05:29 PM
Wifi signal rubbish at best. Nil a lot of time , and now hardwiredsmart tv has stopped working . I've tried the fault findin tests I've had two engineers bt out checked line inside n outside n it's fine I've had enuf now end of tether with it , need a real sky engineer to sort this paying for a substandard service not good
16 Apr 2023 05:48 PM - last edited: 16 Apr 2023 05:49 PM
Posted by a Superuser, not a Sky employee. Find out more@Vivaspeed You're not addressing Sky, this is a customer helps customer frum, no enguineer will be forthcoming on the back of a forum post.
For the forum to help please can you post your router stats so the forum can advise on any issues. This link explains how to do that https://helpforum.sky.com/t5/Broadband/How-to-find-your-Sky-Broadband-router-stats/td-p/2855717#
16 Apr 2023 06:28 PM
Ok thx but can anyone advise what to do or if anyone has had these problems then ?
16 Apr 2023 06:32 PM
17 Apr 2023 02:56 PM
Posted by a Superuser, not a Sky employee. Find out moreIf you've already had engineers out to check the external line and they have said its fine then your problem is likely just local WiFi conditions which Sky have no obligation to fix. If you wish to improve your WiFi you need to look at repositioning your router, changing the WiFi channel, adding boosters or getting a 3rd party router.
