Discussion topic: Wifi signal lost - alarm LED on the ONT module
This message was authored by: SK2712
Hello,
Lost Wi-Fi signal and there is a Alarm LED is ON on the ONT module and there is no Data LED light up.
Re: Wifi signal lost - alarm LED on the ONT module
@SK2712 There are a few different versions of the ONT installed by OR so if you can picture off yours and attach image and post up on the Forum. If it is the Adtran version see the picture once it is cleared for you to see, Alarm use the LOS column!
Use the LOS for Alarm!Use the LOS for Alarm!
