3
This discussion topic has been answered Discussion topic: Wifi router keeps going to captive wifi
This message was authored by: WasimLakdawala
Connection Diagnosis
Not quite connected
We think there may be a problem with the setup in your home.Please note, if you are a Sky Fiber customer and you have recently replaced your router,you should wait one hour for your line to initialise before attempting any of those checks.
Choose the set up below that matches the one in your home click 'Let's fix it'.
You'll then be taken through a series of steps that will help you check the connections with your equipment.
Sky Hub with Microfilter
Sky Hub direct to Phone Socket
Sky Hub with Fibre Modem
Re: Wifi router keeps going to captive wifi
@WasimLakdawala if you have an issue just post somecdetails but at a guess the hub is not connected to the line so devices sre networked but cannot access the internet. Loss of connection between midnight and 5am is often down to essential maintenance on the network. If that is the cause your service will be back up in the morning.
This message was authored by: Chrissy22
The router is on atm but as soon as I start using my laptop it goes to flashing red
@Chrissy22 can you explain what is the colour of your Sky hub, whether it is a new service or has worked before and whether other devices connect normally.
