Discussion topic: Wifi password changed, devices still accept old password
This message was authored by DeadEyeD This message was authored by: DeadEyeD
Hi,
I've changed my wifi password as per the procedure of logging into the router settings at http://192.168.0.1/. I can see the new password on both the 2.4GHz and 5GHz networks yet my devices won't accept this and will still connect using the original supplied password. I've also tried restarting the router but the situation still persists. Any ideas as to why this is happening or any solutions? Thanks
Re: Wifi password changed, devices still accept old password
@DeadEyeDIf you are trying to reset the router back to defaults hold in the reset button for at least 20 seconds.
@DeadEyeD
Do you have Sky Q by any chance?
You may need to power down all Sky Q devices as well.
I am NOT a Sky Employee
DeadEyeD
Yes, we have Sky Q. So power that down when attempting to change the wifi password?
@Highlinder
Not attempting a router reset but will give that a go if the above fails to solve the problem, cheers.
@DeadEyeD
Just after the password has been changed. My suspicion is that the Q nodes are holding the old WiFi password since they act as boosters for your network.
