Discussion topic: Wifi on hub middle flashing orange and going off
Message posted on 21 Mar 2025 09:43 PM
Please can i have a call back i have tested all wires
Message posted on 21 Mar 2025 09:49 PM
Re: Wifi on hub middle flashing orange and going off
As this is a customer helps customer forum then no one will call you due to you posting on here.
The first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
Message posted on 21 Mar 2025 09:50 PM
Wifi dropping out
on the hub the wifi middle one is orange and flashes and then goes off i have checked the connection all ok and and on my sky app everything ok could i habe some help please
Message posted on 22 Mar 2025 07:56 AM
Re: Wifi dropping out
@Jane6294 see https://www.sky.com/help/articles/hub-lights-explained-start the online checker takes sometime to puck up a lost connection but it should havecdone so by this morning and should tell you if Sky are aware of a fulst affecting your line if it doesnt call them and report it and they will get an engineer to check the line but its likely not yo happen until Monday or Tuesday.
Message posted on 22 Mar 2025 10:45 PM
Still having trouble with wifi again this evening can yiu advise my service checker says everything ok
Message posted on 22 Mar 2025 10:55 PM
Have you tried rebooting the hub at the mains, if this continues the two broadband checks showed no issues then all you can do is to call Sky tomorrow about this.
