Discussion topic: Wifi not working yet all the lights are on - Sky says no issues..... Rugby area
Message posted on 28 May 2024 08:46 AM
Is anyone else in the area having this issue? Rebooted twice to no avail. Since upgrading to better faster internet last month having constant problems with connection. Wondering if it is the router as expected to get a new one with the upgrade as current one is pretty old but didn't.
Message posted on 28 May 2024 09:01 AM
Re: Wifi not working yet all the lights are on - Sky says no issues..... Rugby area
Which of these Hub models are you using:
https://www.sky.com/help/articles/set-up-hub-which-sky-hub-do-you-have
Message posted on 28 May 2024 09:03 AM
This one
Message posted on 28 May 2024 09:04 AM
We are in Salisbury SP4 and have the same issue.
Message posted on 28 May 2024 09:05 AM - last edited: 28 May 2024 09:07 AM
That's the SR102 from 2013: with only 802.11n single band WiFi it's effectively obsolete (although still technically in support) and would typically be replaced when recontracting.
The default hardware for Superfast is now the Sky Broadband Hub (2019), and for Ultrafast it's the Max Hub (2023). The Q Hub (2016) is on its way out as it can't do non-PSTN telephony.
Message posted on 28 May 2024 09:10 AM
Thanks! Any idea how I go about getting a new one? I am really struggling to get hold of Sky about anything!
Message posted on 28 May 2024 02:59 PM
I suspect you'll have to persist with calling. They'll probably try to get you to sign up for Broadband Boost or WiFi Max at additional monthly cost, which personally I'd resist.
Message posted on 28 May 2024 04:14 PM
Thanks - managed to get through and they have deemed I need a new router so it is on it's way - here's hoping that fixes the issue although still odd how some things work okay and others don't! Thanks for all your help
