Discussion topic: Wifi not showing up on network list
This message was authored by: Tasha49
We had new wifi installed on Wednesday, and for a while it was working fine, however the day after (today) we have found that the network isnt showing up on any of our devices. I have tried restarting, disconnecting and reconnecting everything, and still no luck.
This message was authored by: SES1973
Re: Wifi not showing up on network list
I have exactly the same issue and when I run the tests to check everything on the MySky App it says everything is fine. I can't work out what's wrong? I've tried searching in my personal mobile, work mobile and laptop and none of them can find the Wi-Fi?
Avatar for Tasha49
We press and held the WPS button for 30 seconds and found that that reset the router and it then showed up
Thanks so much, I've just done the same and mine is working fine now too. Really appreciate your help. Cheers, Simon 👍🏻
