Discussion topic: Wifi not connecting to device
This message was authored by: Anu23
Message posted on 15 Sep 2025 07:32 PM
Hi , I am having trouble connectinf my devices to the wifi , some are connected and some wont connect and show poor strength but when i've checked the wifi strength on the sky app it shows aa good
Message posted on 15 Sep 2025 07:45 PM
Re: Wifi not connecting to device
@Anu23 Has all off this just started to happen, or did you have an upgrade, change off service, change off hub etc. What devices are you having trouble with and which sky hub do you use!
