Discussion topic: Wifi keeps disconnecting from one room to another, range is poor
This message was authored by: Rohit5
I have just switched to sky and have noted that the range and connectivity are not great. As we move from one room to another the wifi keeps dropping. Very limited range to the back rooms.
Also, need to manually connect to wifi if you come back home!!
This message was authored by: Greenfingers001
Re: Wifi keeps disconnecting from one room to another, range is poor
Hi there @Rohit5 , I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Avatar for Rohit5
No one from Sky has contact till now about this issue.
The issue is persistant.
