Discussion topic: Wifi issues and no phone line connected.
This message was authored by: BeverleyLee
Since having fibre installed last week. Our home WiFi connected is less reliable than be we had fibre, it disconnects and reconnects frequently and we only have 4 bars when neighbours have 5. Also I still have no phone line connection. Fibre was supposed to improve things not make them worse. Please advise when this will be resolved.
This message was authored by: peter-marlow+1966
Re: Wifi issues and no phone line connected.
Have plug  the phone  into  the  back  of your hub ? If you are on full fibre broadband to the property then the old  phone  line will  not work and have you run a service check through  the sky website  or my sky app?
P c marlow
@BeverleyLee Is the phone now plugged into the back off your sky hub, but 24-4hrs is enough normally for it all to work, so you need to get onto sky about that by calling them. 2 parts to the phone outgoing and incoming calls and one may work before the other so check both parts off that!
