Discussion topic: Wifi is very slow affecting 2 laptops and mobile phone
This message was authored by: JL11
2 laptops are struggling with stable wifi, and apps on an hone  struggle to load, frequently fail - all started about 3 weeks ago.
Have done all the usual rebooting devices / router etc
The Sky broadband check says errors, goes through checks, gets me to re-plug in everything etc, says everything is fine but when I run the check again, it says its got issues and round it goes.
Am reasonably techie so believe all relevant tests run, where do I go next?
