09 Dec 2024 02:47 PM
I live in a 1 bedroom flat and my wifi doesnt stretch the full property.
09 Dec 2024 02:57 PM
Posted by a Superuser, not a Sky employee. Find out more@Rosey13 WiFi in blocks of flats can be difficult especially if the internal walls are made of concrete. However I would expect the signal to be strong enough to connect to but given in most flats you are surrounded by neighbours each with their own wifi networks all compteting fir the limited number of WiFi channels so interference is almost a given which makes streaming video and playing games a pain.
Check your hub is in the best possible position which is on a surface out in the open. After that you are into needing wifi extenders whuch Sky can supply if you buy their Wifi Max bundle see https://www.sky.com/help/articles/sky-wifi-max
