Discussion topic: Wifi in the house
Message posted on 07 Jun 2025 11:02 AM
Wifi in the house
Message posted on 07 Jun 2025 11:53 AM
Re: Wifi in the house
@Elia Was it good before and you now have a problem, if so what has changed your end if anything?
Message posted on 07 Jun 2025 01:05 PM
Message posted on 07 Jun 2025 01:37 PM
@dt138 The hubs are not apples to apples for operation, if you have NO wi-fi6 devices that are able to connect then no need to have a wi-fi6 hub!
Message posted on 07 Jun 2025 02:03 PM
Hub 6 was offered to me. Frankly I didn't even know it has Wifi6. As it happened, my phone uses WiFi 6 and my work laptop, and noticeably it is my phone has most WiFi issues, spinning circles or WiFi drops off switching to Mobile data etc. Same phone, no issue with old router. Hope its just a faulty router.
Message posted on 07 Jun 2025 02:26 PM - last edited: 07 Jun 2025 02:29 PM
@dt138 Have a problem with a Samsung A54 falling off with speed only on the Download side, nothing to do with the hub it is purely a phone issue, everything else is running as expected.
When i see it on the mobile, the fix is wi-fi off wait 10 seconds wi-fi on again and back up to full speed.
Message posted on 07 Jun 2025 04:31 PM
Download speed on my laptop isn't much better. Uses wifi6 and has a good spec.
Maybe there are other causes. But as far as I can tell, nothing has changed in terms of home setups, number of devices between now and 1 month ago, apart from this router.
When writing this message, the Internet radio just went off on my phone on wifi, good connection signal, but no data transfer. 15 seconds late, it came back. Very intermittent.
If anyone has a fix, please share, getting fed up with the disruption. Wired connection to my router dropped off too, so it's not just my phone and WiFi. So far, everything is pointing at the router, even Sky Q box cant get connection to load tv schedule or my recordings.
Message posted on 07 Jun 2025 04:36 PM
@dt138 If you have not already done so would suggest you look at dropping the wireless WPA mode back to wpa2-psk for the sky max hub.
