Discussion topic: Wifi dropping out and unable to connect in every room
Message posted on 14 May 2025 04:27 PM
We are having issues with the wifi dropping off connection in some rooms and other rooms we cannot get WiFi at all
Message posted on 14 May 2025 04:30 PM
Re: Wifi dropping out and unable to connect in every room
@GaryCockerill Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
