Discussion topic: Wifi dropping in and out
Message posted on 03 Jul 2025 12:23 AM
Having lots of issues with wifi dropping out
Message posted on 03 Jul 2025 01:51 AM
Re: Wifi dropping in and out
So am I. It's going on now for months. I work from home for an emergency company.
Have contacted sky a few times and they said they could see it on the system, but it never get resolved properly.
Message posted on 03 Jul 2025 04:51 AM
@colinskyconorluke
Wi-Fi is the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
For customers working from home please remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
