Discussion topic: Wifi dropping in and out
This message was authored by: AW23
My WiFi keeps dropping in and out. Service checker isn't flagging any issues with my broadband or WiFi.
Sky hub has green, flahsing amber, green, amber lights
Re: Wifi dropping in and out
@AW23 Your hub knows that there is no broadband and indicating that by going to the Amber light status, does not mean that Sky have any idea to what the particular reason is and the same goes for the service checker software. Diagnostic may be better or more help!
This should determine if there's an identified fault affecting multiple households.
Try running the line test here to see if any faults are found:
