Discussion topic: Wifi down in Gosport
This message was authored by: NickCappello
Have try to reset start BB hud and TV pug but only two of the four lights on the hub come on.
Re: Wifi down in Gosport
@NickCappello  First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
This message was authored by: Kitty462
I have no Internet connection in Gosport either. Hub was showing green and  said connected no Internet. Might an area thing?
@Kitty462 power down your hub for an hour as thst normally sorts the issue of the hub being connected but no data passes.
