5
This discussion topic has been answered Discussion topic: Wifi disabled but still visible and working
This message was authored by: warbkingtonlounge
Hi, I've disabled the wifi on my sky hub as I've connected my deco m5 mesh via ethernet to the hub and have the set in AP mode.
However, my sky hub still shows in my wifi list and I'm able to connect to it!
I checked the router and is says wifi disabled and the wifi led is out.  I cant check further as I changed the router log on password from SKY and like a fool have forgotten  it.....
Any ideas?
This message was authored by: Highlinder Answer
Re: Wifi disabled but still visible and working
@warbkingtonlounge  Just hold the reset button on the back of the Sky router and it will reset it back to factory. Around 20-30 seconds should work.
Avatar for warbkingtonlounge
Level 3 icon
Will it be
Admin
Sky
@warbkingtonlounge  Which router did Sky send you from the link below
Level 3 icon
Sky broadband hub.
@warbkingtonlounge  That will be admin as the username and the password will be on the back of the router.
