Discussion topic: Wifi constantly stops working and won’t re connect
This message was authored by: Unhappytothemax
Absolutely useless turns off with no reason I do all the resets multiple times and mains. Everything and nothing works for over an hour even though my stupid checker says my wifi is all working and so is the broadband when it's yellow lights on it infront of me and all my devices are down again. Now after trying about 10 times over the last hour it randomly turns back on, for the amount of money I spend this is a total joke
Re: Wifi constantly stops working and won’t re connect
@Unhappytothemax
Try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
Avatar for Unhappytothemax
This is what I have stated I have already done multiple times. The company say it's all lighting up green but multiple times for multiple hours last night this wasn't the case and none of the instructions on how to fix it would work it would just randomly after an hour - 2 hours come back on.
sky app and website is such a poor person takes a day of waiting to get to a person to help who just tell you to follow the instructions...
@Unhappytothemax To aid you further and you are aware the Forum is Cust - Cust, what sky hub do you have and what do you see with regards to the link below!
