Discussion topic: Wifi connectivity other rooms
This message was authored by: lottieprimrose
Poor connectivity to wifi when using devices outwith the same room as the wifi hub.  This is occurs both with laptops and mobile phones.
Re: Wifi connectivity other rooms
@lottieprimrose Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
Avatar for lottieprimrose
Cheers. I require the wifi extenders as I had already upgraded to the Wifi max.   Can't find the route to get through to Sky to now request the extenders.
