Discussion topic: Wifi but no internet
This message was authored by: AD90
No Internet connection but can connect to the hub. Slow flashing green light, have reset multiple times.
Re: Wifi but no internet
@AD90
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your devices and your hub. Broadband is the actual internet connection provided by your ISP (Sky).
If your broadband still isn’t working after 0700 use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
