1
This discussion topic has been answered Discussion topic: Wifi but no internet
This message was authored by: Clops74
Things are connected to the WiFi but they are all saying no Internet. So no sky tv or games consoles.
Re: Wifi but no internet
@Clops74
If your broadband isn’t working use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
@Clops74
