Discussion topic: WiFi won’t let me go on internet
This message was authored by: Peevee22
Broadband isn't working on internet, have to use data
Re: WiFi won’t let me go on internet
@Peevee22 Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
This message was authored by: Brad14
I have the same problem. All the diagnostics say everything is ok and I've reset everything - yet the Sky broadband works on some websites or apps and not others. There's no pattern either - working differently on different devices etc. A few people are posting the same issue and zero help from Sky ("ask the community" = their customer service)
