Discussion topic: WiFi weak and lagging on Xbox despite prioritising it
This message was authored by: Amber1711
The WiFi connection to our Xbox is weak and lagging despite prioritising the device.
This is becoming a regular occurrence.
Re: WiFi weak and lagging on Xbox despite prioritising it
@Amber1711 Have you tried Ethernet connecting the X-Box!
Avatar for Amber1711
Level 0 icon
No! How would I go about this is the Xbox is on upstairs bedroom and WiFi hub is in lounge downstairs?
@Amber1711 if the wifi signal is weak in the area of thhe Xbox prioritsing it will not reallybhelp. Ideally games consoles should be networked usin Ethernet cables although powerline adapters can also work. If you are determined to use WiFi you may need an extender ir similar which Sky can supply as part of the WiFi Max package.
